My Book USB folder problem
I have an My Book USB (Elements, I believe) where I deleted the My Music folder from.  I was going to copy my updated My Music folder from my PC, so I just deleted it.  When I created a new folder for it, it didn’t have the same icon.  I know how to change it, but was there anything special about that folder?  Is there a way to put it back in.  I couldn’t find it in my Recycle Bin, so it looks like it’s gone.  Any help would be appreciated.  Thanks.
As I was wondering more, does the My Book USB hard drives come with any built in folders, such as My Music, My Documents, etc, or could that have been something I copied from my pc directly?  I’m just trying to see if I screwed anything up with the folders.  Thanks.
The Elements is a plug and play drive. If you create a floder on it you can give it an Icon by right clicking the folder and in properties select customise tab then you can add or change the Icon.
Joe
