I have a My Book Studio Edition for Mac that is constantly running. It doesn’t back up, and it gets very warm.
I unplug all the cables for a couple minutes, and replug them, and click the “Backup Now” command. It does the backup, but the next scheduled Backup… it will run constantly for hours without doing the backup… the same as it did before?
I am using the Time Machine software… and the Energy Saver is set to put the computer to sleep after 12 minutes.
Even though the computer is asleep, the External Hard Drive keeps running without doing any backup and gets very warm.
I called WD this morning, and they said that I can return it, and they would send a replacement refurbished one back to me. I have read in other forums where people have received refurbished items from the manufacturer, and they were in very bad shape. So I don’t know if I will send it back, or get a new External Hard Drive.
Do you know anything about WD’s replacement program?
one of the odd things I saw with Time Machine is that if it got interrupted during a backup, then the next time it does a backup it verifies what was backed up previously - this can take a very long time - and there is no indication of what is going on (except for a spinning Time Machine icon for hours …)
I found the best thing to do was essentially wipe the drive as mentioned above, however one more step:
In Time machine preferences, it might get confused by a drive that has been reformatted (mine did)
The solution, was to “Select Disk” and set to None. Click OK, come out,
go back in and set the drive to your Western Digital drive.
This seemed to reset things properly - the first backup took a fairly long time, but after that it only takes a few minutes (assuming not much has changed.)
I had a G-Drive for my old Mac and it worked like a champ. I was trying to save money by this WD My Book 1TB but now I am thinking I should have spent the extra money for a G-Drive. The transfer rates for this WD are way too slow.
