My Book Home Edition 1.5tb usb 2.0
I have a WD My Book 1.5tb USB 2.0. I backed up my part of my computer to it in 2014 and got it out to copy pictures onto it. When I drag and drop, a screen says Windows is shutting down, my computer shuts down and restarts.
Are there any driver updates for this External Drive? I have Windows 7.
Thanks.
Are you getting same issues on another computer?
You can try to check updates of My Book using WD Universal Firmware Updater.
https://support.wdc.com/product.aspx?ID=136#WD_downloads
I only use it on this equipment. I will try the universal firmware.
Thank you for your help.
Kathy
