Nothing happens when it is plugged to my laptop (not recognized).
The last thing I did before the disk fail: I copied some files (<5 gb) from my laptop to the external drive, one of those files had a long name (there was a warning message), then I set the computer to sleep mode, after about 30 minutes turned on the computer and the drive didn’t work anymore.
What do you think about this problem ? I read forums on this web site, but I didn’t find a similar problem.yet…thank you in advance for any suggestion.
Hello, you can check if the My Book is still recognized on the disk management window. If it is recognized, run a test with DLG, this way you can verify if the My Book files are corrupted or it has a hardware problem.
Another option you can try is using another USB cable, if that fails then the My Book would appear to be faulty, to replace it you can follow the steps from the link below.
