My Book Essential 3 TB not listed in My computer, disk management, device manager
 Hello, I have a problem with two My book drives - 2TB - 3TB both are full.
These drives spin up fine, no noise at all however they are not recognized in my computer,
disk management or device manager.
I did some Google research and learned that you cannot simply remove the hard drive and install
it into a desk top PC because windows will  be unable to read the data since it is encrypted as its
written to the disk through the control board.
Obviously both of these My Book drives are in need of new control boards, I have gone through all of the elimination
checks recommended to connection of the drives in these forums.
If anyone knows of another solution before I purchase new control boards please come forth.
The 3 TB is still in warranty however, I just don’t want to swap all my data for another blank drive.
Control boards are about $25 each, I feel I have spent enough for these drives already.
        Regards
You might look onEbay for a board. This link explains abit about matching them up http://community.wd.com/t5/Off-Topic-Discussions/Bridge-Boards/td-p/353839  It sounds strange that both drives go bad at the same time. Are you sure it isn’t a problem with the computer in the USB path? Have you tried plugging the power directly into the outlet instead of a surge protector? Also don’t use a hub or a cable longer than the one provided. Have you tried themon a different PC?
Joe
Thank you for your reply, yes I followed all the instructions you have listed and  from the links here to resolve this issue
also the 2 TB drive quit about 8 months prior to the 3 TB drive, I did register the 3TB drive and it is in warranty
but Im going to want to recover the data.
I have an open ticket with support and they suggested what you have here, I replied to them that it did not work
and that I believe the control board is bad and that I have found in many reviews from electronic retailers
that there are many people with this issue.
After that message, support must have taken an offense because they haven’t contacted for 3 days now.
I believe your right, I have found a seller with this board and the other, they are $25 each, I was trying to avoid that
but it looks like there’s no other way.
Thanks for that link for maching up the boards, I’ll make good use of that before buying.
                                                         Regards
