I recently bought a 2TB My Book Essential USB 3.0. About 2 weeks ago i unplugged the My Book to move it and when i plugged it back in it showed up as a Local Drive G: and then it says if i want to format it. I do not want to format it until i try other solutions. I am currently using it on Windows 7. Also It was first used on my desktop with vista but i no longer use the desktop so i just use it with my laptop now.
Also under disk management it says RAW instead of NTFS.
Thanks for the help. I tried the FindandMount option and it could not find any partitions at all even with the comprehensive scan. I also tried TeskDisk but could not get that to work either. I will try TeskDisk again maybe i did’nt do it right but is there anything else?
You can try a Linux Live CD and see if you can get data off or data recovery software like Recuva. There are a lot of them some are free others try and buy. Then there is the command I mentioned it’s in the middle of the page on MS link.
