My Book Duo with two computers attached to and other questions
Hi there,
I am looking into getting a MyBook Duo 12tb and was wondering it is possible to connect multiple computer to access it like a NAS. There are two USB 3 ports, can they each be connected to 2 different mac pro simultaneously?
Also, if I remove one of the disks, plug it into a cradle to a pc, will it mount (assuming it is formatted in ExFat)?
Finally, are they hot-swappable?
Thank you
No, it’s not possible. USB disks can only be accessed by ONE PC at a time. Even with a USB “switch,” only one PC can be active.
The USB ports on the My Book Duo are basically additional ports. Think of the Duo as having a built in USB Hub. They’re extensions of your PC’s USB port, they are not for connecting to other PCs.
Thank you
