My Book Duo - where to find WD SmartWare Pro
Hi there,
I bought a “My Book Duo”, now I simply don´t know where to find the WD SmartWare Pro software, which is supposed to be included. Where can I download it?
Thanks!
This drive has WD Smartware for Windows not for Mac.
You can find it on the link below:
http://downloads.wdc.com/smartware/WDSmartWareInstaller_2.4.16.16.zip
http://support.wdc.com/product.aspx?ID=134&lang=en#WD_downloads
Ok, I see, thanks! Does the My cloud personal solution support Smart Ware on both Win and Mac Os? Maybe I´ll get that one than
