Can I use my “MyBook” back up drive as a ordinary HD?
Hi baz,
You can use your My Book as Desktop External Hard Drive. To use the advance features of the drive you can refer to the link given below for User Manual.
For more information, You can contact WD’s Technical Support team from the link given below.
https://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support.
