I have a 4TB WD My Book External Hard drive which is about a year old. Until this past month it was hooked up to a Dell 420 desktop running Windows 10 as an external drive, along with a Toshiba portable drive. The My Book ran fine except for powering down in times of inactivity, but it would ‘power up’ as soon as a mouse button was clicked. (By this I mean it would go into a sort of sleep mode, and you’d hear it starting up when you’d click on it, but it would NOT disappear from Windows.).
This month I purchased a HP Z420 Worksatation with a Xeon processor. I installed Windows 10 on the Z420, which had Winodws 7 on it when it arrived, then, once I had the same operating system on it as the old Dell, I plugged in both the Toshiba portable drive and the WD My Book.
It was recognized by Windows 10 and all my files (about 2 TB) were there. At first all ran well, but while using DAZ Studio Pro to do a 3D rendering (which I did also on the old computer with the My Book attached) I came back after letting the rendering run for a few hours and found that the My Book drive had disappeared from Windows. It did not even show up on my screen, so I unplugged it from the USB port (a 3.0 port on the HP) and plugged it back in, but that didn’t change anything. Only when I unplugged the power and plugged it back in did the computer find the My Book and it ran great again.
I figured it could be a sleep mode problem so I set to NEVER the power off the HD function in Win 10. Yet whenever I run a render in DAZ Studio and let the computer run for – let’s say-- over an hour, the My Book eventually disappears from Win 10 and has to be unplugged from the power supply to reappear. I’ve spent hours on-line reading about similar problems with various portable and external drives of various manufacturers and I’ve tried various things. I’ve disabled USB ports from ‘going to sleep’, I’ve checked the drivers and downloaded the WD SES driver directly from WD and installed it. Before that I tried updating the driver in Device Manager and it claimed that the most current driver was installed (which was the same one as the one I installed later from WD). At first the WD was plugged into a USB 2.0 port (like it was on the old Dell, which did not have USB 3.0 ports) but after the first incident, I changed the port to the 3.0 port and the same thing occurred. The Toshiba drive (a 2TB portable drive that is about 2 years old) is running perfectly along side it and never disappears. I’m fairly sure it isn’t DAZ Studio Pro causing the event as I’ve used this program for 6 years without any problem on various computers.
I think it is the dormant time that is causing the external My Book to disappear. What I was wondering is if it could be caused by some of the WD software or something hard-wired into the drive to shut down after a period of time. The data is all there when it is plugged back in after an episode and I have the computer set to not go into sleep mode at all (except for the monitor). When I am actively using the computer, the drive remains there. I can save and retrieve data from it normally and there are no error statements. Any suggestions would be appreciated, I use it primarily to store files related to DAZ Studio, and I back up to both the WD drive and the Toshiba drive, but i’d hate to lose the data already on the WD, as it takes nearly a full day to transfer the files to another drive.
