I’m backing up about .5TB of content but my 3TB drive is near capacity. How can that be?
More information is needed. Which operating system do you use? Which file system is your unit using? How large are individual files? Are you certain your WD My Book has enough free space?
Windows 10.
I’ve used nearly 3TB on the drive backing up, but I only have .75TB to back up. I’m getting apparent duplicate backups.
Thanks.
Best regards,
Scott Morrison
Dimensions in Quality, LLC
MBA, ASQ-CQE, CQA, CMQ/OE, CSSBB
Exemplar Global Principal Auditor 96409
713-201-3725
http://www.diminq.com/ www.diminq.com
