my android phone id showing "blank sd card or has unsupported file system " error message and is not showing the contents of the memory card…can anyone please help me with this issue?
in that case you can try to format the card with the pc and see if the same issue happens with the mobile. If the card after formatting has the same issue then it seems that its defective and needs to be replaced.
so in that case you can contact Sandisk for a possible replacement
http://kb.sandisk.com/app/rmaform/session/L3RpbWUvMTQ0MDU3NzcyOS9zaWQvcGluTlZTdW0%3D
