Hi All
does anyone know which driver would enable me to get the best performance out of my ssd?
Thanks
Tim
Hi All
Thanks
Tim
performance is pretty much the same no matter which driver you use. depending on what type of chipset your MB has would be the best way to choose. If you ahve an intel chipset many report slightly better performance with the Intel Driver. that said either should work in most all hosts with little performance differance.
here is a good comparison on the crucial forums.
