What is the difference between Imagemate Pro and Extreme Pro
There’s no difference in specification, it’s just aesthetic,
Imagemate is sold by Wallmart and Extreme PRO and sold by anyone.
** Não tem diferença Bruno, IMAGEMATE e apenas vendido pelo wallmart, e só marketing
I realize this is an old thread, but are you saying the two cards are identical. The Extreme Pro is listed as tested by GoPro while the ImageMate Pro is not. I have an ImageMate Pro SDXC that I would like to use with a new GoPro, but am not sure as it is not among those listed as tested by GoPro.
ImageMate PRO microSD cards are technical equivalents to SanDisk’s Extreme PLUS line of cards. Per GoPro Support, SanDisk Extreme PLUS microSD cards are confirmed as compatible with their HERO line of products (HERO10 Black and newer), so that compatibility can be extended to include SanDisk ImageMate PRO cards.
Please see the following link for confirmation:
GoPro Support - SD Cards That Work With GoPro Cameras
Thanks for the reply. I am aware that the ImageMate Pro and the Extreme Plus have similar specs, but are they in fact the same cards? Obviously, similarly spec’ed cards could have different reliability, heating issues, etc, depending on the quality of manufacturing and of the card itself.
