Just bought a 400 GB micro SD card. I keep getting errors on the SD card while it is trying to move the music to the card. “Could not find this item this is no longer located in s verify the items location and try again” then “do you want to scan and fix removable disk f?” Then “are you sure you want to copy this folder without its properties?”
