I recently Sansa C250 and am very pleased with it. My only issue with it is that I have a hard time seeing the menu options due to the similarity of the foreground and background colors between the menu and the highlighted option. In bright daylight I can not tell which option I have highlighted. Inside I can see what I have selected but it is very difficult. I have tried changing the Display options, but there is on ly a Brightness setting and this does not really help. The ability to change contrast would be helpful. The best option would be the ability to select a display option where the highlighted selection is the reverse colors of the other menu options, or some similar obviously different foreground and background color choices.
I am experiencing the same problem. Can we get some help?
