Hi all,
Just got my new clip and it is awsome !!! well pleased with it.
Would one of THESE be ok with my clip.
Cheers Greame:smiley:
Hi all,
The amperage is fine (500 mAh), but the voltage may be high at 6 V.–you should look for a 5 V. output charger (which is common). (No electrician here–perhaps someone else will have a better idea of this.)
Thankyou , got one:stuck_out_tongue:
6 volts is wierd, I wonder if it’s a typo. USB spec is 5 volts, .5 amps. Many USB chargers will have higher amps (1 amp is common), which is fine (just charges faster). But I’ve never seen one that wasn’t 5 volts.
