Mach16 sata 100gb ssd
I’m trying to determine if the following two products are technically the same and if they can be used interchangeably:
Original: by STEC The SSD Company model no. M16ISD2-100UCO
Replacement: by HGST model no. M16ISD2-100UCU-C01-TKF
Basically, can i use the M16ISD2-100UCU-C01-TKF in a Kontron Pocket PC application?
Should be OK but I have seen cases where a vendor as blocked using replacement parts
