I have a Macbook Pro (running on El Capitan) with two WD My Passport Ultra (2TB). They are connected via a powered USB3 hub where I also plugged in my Wacom Intuos tablet.
When I want to boot my Macbook with the hub connected, the Macbook will fire up but won’t show me the login screen. All I can do here is a “hard” switch off.
I have to disconnect the hub, hit the power button, wait for the login screen and then I can connect the hub to get everything working. It works fine then but this can’t be a solution.
Hi Alex,
thanks for your reply. I’d say that the issue is gone—I just connected both drives directly to the computer. It booted but slower than normal.
Seems that I just solved the problem. The hub was powered with a 0.45A power supply. Maybe that was underpowered. The hub is now powered with 2500mA—no booting issues so far.
