ive confirgured my passbook to mac but now cant watch the movies on it on my tv?? is there anything i need to do?
Hello and welcome,
What file system did you used to format the Passport? If you used HSF+, then you need to check if your TV is compatible with that format. Most TV’s are compatible with FAT32, which is also compatible with MAC’s, the only limitation is that you won’t be able to save larger files than 4GB, check the TV manual to see what files systems work better for your. For more information, check the link below.
How to partition and format a WD drive on Windows (8, 7, Vista, XP) and Mac OSX
