I was looking for an easy way to create m3u playlists for the Sansa Clip on the mac, so I came up with this little app.
It should work with other models if they also store files under /MUSIC
What it does:
The program searches the /MUSIC-directory for subfolders, creating filename-based m3u playlists in each of them.
The app will delete any existing m3u-files below /MUSIC !!
HowTo:
- Copy the m3uGen app to the root directory of your SANSA CLIPs filesystem
- Run it from that location.
Use this program at your own risk!
