I while ago I stupidly left the power and USB cables plugged into my 2TB Western Digital external hard drive when I moved house.
Afterwards I noticed that the USB port had become loose and I had to push the cable in a certain direction to get my computer to recognise it. This made it looser over time and then it stopped connecting at all. So I decided to take it apart and it appears that the port has almost detached from the circuit board, which I’m assuming was why I had to move it around to get it to connect.
So the question is, if I just do some basic soldering to attach 3 of the 4 corners of the port back to the circuit board, will it start working again? I just want to take all of the media I have off it, but if I can salvage it to put back in the case and use again then that would be great too.
Thanks in advance
