Hello,i’d like to know if is there a way tu mutualise the 2 libraries (player and SdCard) in the same menu ?
I think it’s a little annoying that i have to search for a song in the 2 menu.
Thx.
Thx.
its not “a little” annoying. its a major flaw and should be fixed by SanDisk ASAP.
Unfortunately that won’t happen. It’s a fundamental limitation of the Sport (among others) – as discussed at other occasions in this forum.
