Ive just cloned and moved from my old 120gb corsair force 3, to a 480gb sandisk ultra II and found that I need to install Internet Explorer 9 or higher to install the ssd dashboard. Why??
Its very disappointing considering how poor IE has been with regard to security issues to the extent that even governments have even urged users to switch to something else from time to time.
Plus, the many users who have deliberately removed IE for the above and others reasons, now have to increase the vulnerability surface of their systems (not to mention the inconvenience) merely to check/update the firmware on their ssd? Sigh…
Can you please remove the requirement for IE to install/use the dashboard asap. Keeping it is kinda poor form guys.
The minimum requirement in order to install SSD Dashboard is IE 9. The IE engine is used to render the UI so it is an essential component. It is up to you if you want to use or not the IE browser. You may as well un-installed it, but Windows will always have the IE engine installed because Windows is also using it other then just for Browsing. I suggest you install IE 11 and un-install the Browser. That way you upgrade your engine and you still not using IE browser.
Im using Windows, but not launch IE even once. Just install other browser from .exe file. Don’t want those spy from cia or any other authorities collect my info and read messages. So i can’t use SSDdashboard (((
George, youre wrong. I run windows 7 Ult x64 and never needed or had installed Internet Explorer until SanDisk SSD Dashboard required it for its installation.
Youre suggested solution not to buy Sandisk SSDs for a windows pc is lame and unhelpful.
Certainly, I wont buy sandisk again. Back to corsair for me.
The CIA is not relying on IE to spy on people. If they want your data they will get it whether you have IE installed or not. Also as georgealon has said you can uninstall it right after the dashboard is installed but regardless you will not be able to use the dashboard if the IE engine is not there.
