Installation software/drivers?
I bought my passport ultra 1tb drive to use with a computer-run karaoke program.  I was assured when I bought it that it was a plug-and-use kind of the item. But when I went to use it the first time, the installation wizard called for me to search the internet for software.  I DO NOT connect my karaoke computer to the internet as I do not wish to risk a virus wiping out my entire database.
It seemed to work fine, despite the ‘error in installation’ messages, but there were a few glitches when the program tried to access the files on the passport drive.
When I searched the passport site for the drivers, it gave me a list of things that appear to be add-ons or extras but nothing that said ‘drivers’…
My questions are: Which of the downloadable files are required for efficient operation of the drive?
                                 How can I go about acquiring/installing these necessary files without connecting that particular                                             computer to the internet?
Hi BloodmoonKJs, there are no necessary programs that you need to install to use the Passport. You can click on start, computer and then on the Passport icon to access it, inside you will see the Passport manual and the installation file for the free backup software called Smartware, but it is not necessary to install it. You can just copy and paste your files, just like any other USB memory.
