import problem
I use the USB Key “iXpand Flash Drive Go” and the app called “ixPand Drive”.
I want to put a PDF file from my computer to my USB Key, it’s OK
I want to share the PDF file from the USB Key to my iPad 9 (Notability for exemple) and it doesn’t work… I must copy the file in “Files” and then import the file in Notability App…
Could you help me ?
Hi @matadapt65,
If you’re doing the right thing by copying the PDF to “Files” and then importing it into Notability. This workaround should work for now, but you may want to contact the app developers.
