I’m using a Mac and have a USB drive formatted as NTFS. I can read files on it, but I can’t copy or move anything to it from my Mac.
I use this USB between macOS and Windows, so I don’t want to reformat it. Mostly for transferring large files, so I need something stable and easy to use.
Can anyone recommend a good NTFS for Mac tool that actually works well for writing to an NTFS USB drive? Looking for something reliable from real experience.
The earlier version of OS X or macOS does not support NTFS by default as NTFS is a windows file sytem developed by Microsoft. You need 3rd-party NTFS for Mac apps for accessing NTFS drive on Mac.
Don’t use the free NTFS-3G command line tool as it does not support newer version of macOS. It it just a wast time. You can see the app not being updated for more than 5 years. In fact, there are many easy and relaible NTFS for Mac tools available now!
SysGeeker NTSF for Mac, one of the best apps I have used for reading and writing NTFS drive on my Mac. The Apple community recommends using it on your Mac:
P.S. Many NTFS for Mac apps still don’t add support for Apple Silicon Mac or the latest macOS Tahoe.
Your Mac actually has a hidden, experimental ability to write to NTFS drives. This method involves using the Terminal to turn this hidden feature on.
Here is how it works:
1.Connect your NTFS drive and note its exact name (e.g., “MYDRIVE”).
2.Open Terminal (in Applications > Utilities) and enter sudo nano /etc/fstab. You will need to enter your admin password.
3.In the file that opens, type LABEL=MYDRIVE none ntfs rw,auto,nobrowse (replace MYDRIVE with your drive’s actual name) .
4.Press Ctrl+O to save, then Ctrl+X to exit.
5.Eject and reconnect your drive. It will now be hidden from your desktop. To find it, open Finder, press Cmd+Shift+G, and type /Volumes .
Using the Terminal method to enable NTFS for Mac tool support is a free way to read and write NTFS drives on macOS, but it’s somewhat temporary and technical.
This method enables read/write support temporarily. The drive will revert to read-only after a restart unless you automate the process. For a more persistent solution, you might consider editing system files or using third-party free NTFS for Mac tools, but these can be more complex and risky.
Since you’re using a Mac and need to write to an NTFS-formatted USB drive without reformatting, you’ll need a reliable NTFS for Mac tool. While macOS can natively read NTFS, it doesn’t support writing by default, which is why you’re unable to copy or move files to the drive.
If you are looking for the best NTFS for Mac tool to write to an NTFS USB drive. You can try the FUSE for macOS with NTFS-3G. FUSE (Filesystem in Userspace) combined with NTFS-3G is a popular open-source solution that enables read/write support for NTFS drives on macOS. But slightly more complex to set up compared to commercial options; occasional stability issues depending on system updates.
If I remember correctly, since macOS 13 Ventura, tools like Mounty, macFUSE, and other free methods can no longer properly read or write to external disks formatted in NTFS. This is mainly because Apple
To transfer files from your Mac to a Microsoft NTFS-formatted USB drive and modify existing data, you could try software like iBoysoft NTFS for Mac to enable full read-write access. Furthermore, it fully supports macOS 26 Tahoe and Apple silicon (M1, M2, M3, M4, and M5) Macs.
If you do not want to use additional software, there is another workaround - create two partitions on your USB drive: one partition for Windows (in NTFS format) and another partition for transferring files between Mac & PC (in exFAT format, which does not have restriction for the file size) .
Read also: [Fixed] Unable to Copy Files from Mac to External Hard Drive
