Below I will be suggesting you the manual methods on how to extract files and folder from backup.
Windows prompts that extracting specific files from the backup is not possible. To perform the task without issues, click on the “Disk Management” option.
Now, using the .vhd or .vhdx file extension, system images are stored as a VHD file. Thus, by using Disk Management, you can mount the VHD file as a separate disk. With this simple option, it will be possible to extract specific or individual files. Besides, it also makes it possible to browse the contents of a system image.
If you are looking forward to attaching extract files and Windows Image Backup, below guidelines will be useful. The primary task that needs to be performed here is the creation of the Windows System Image. It is an excellent option when you need to know how to extract individual files from system image backup in Windows 10.
Step 1: The first thing to be done is to select “This PC” and then click on the “Manage” option. A pop-up window shows up, and on the left panel, you can see the “Disk Management” option. Go ahead and click on it.
Step 2: Now, go to the “Action” menu in Computer Management. Here, you should choose the “Attach VHD” option.
Step 3: To locate the system image backup file, select the “Browse” option. To start attaching VHD, press the “OK” button.
Step 4: It is important to assign your partitions to the drive letter. It is because it will be impossible to access the partition without a drive letter. Thus, to assign, you have to head over to the “Change Drive Letter and Paths…” option. For that, right-click on the partition, go for the option mentioned above and add a drive letter.
Step 5: For example, assign “M” as the drive letter. To open the File Explorer, proceed to press “Win+E” keys. To locate the files that you want to retrieve, double click on the new drive. Copy them onto a different drive.
Step 6: In the “Disk Management” window, there is a “Disk” that corresponds to the VHD. So, right-click on it and choose the “Detach VHD” option. This move will detach the mounted drive. You should do it when you have copied all the files from the backup.
Second alternative to extract files can be the use of data recovery software. If you find the above methods complicated you can take the help of a data recovery software
