I bought an 8TB EasyStore, and it came with WD Backup, which now shows me no restore options
So, I backed up some stuff I’d been running on a RAM drive, in case I ever randomly lost power or my PC shut off. Well it did. So now I have this folder called WD Backup.swstor (with assorted things inside), but in the WD backup screen, there are no files to restore. What do I do???
Hi @Nuka,
WD Backup has reached its end of support life cycle.
It is recommended using the built-in utility from Apple for backing up a macOS computer. Please refer to the article macOS: Time Machine Backup and Restore to a WD DAS]Time Machine Backup and Restore from macOS to a WD External Drive
For windows : File History Backup and Restore to a WD DAS
Link: How to use File History Backup and Restore to a WD External Drive Using Windows 10 or 11
As an alternative: AcronisTrue Image for WD https://download.wdc.com/acronis/AcronisTrueImageWD_WIN.zip
