How to view individual files and photos before restoring?
I have a My Book 6 terabyte external drive
Depending on the software that you used to create the backup, you should be able to see your files through windows explorer.
What software did you used?
I used the software supplied by WD with the drive. I have Windows 10.
I used the software that came with the My Book. It was built in. If I use Explorer to see the files do I use Explorer to connect to the WD device I have?
