Hello I currently purchased SN850 and understand firmware update is available via Dashboard S/W on PC. However I am going to use my drive on PS5 and found that there’s no way to update my firmware via PS5 directly.
Is there anyway to update my SN850 via PS5 directly?
Also, if I update via PC, won’t I need to reformat? Once when connecting to PC, then again when put back in PS5? If reformat is needed, does the firmware “stick” or is this erased upon PS5 formatting?
The firmware has to be updated via a PC. The PC doesn’t need to be able to read the partitions in order to update the firmware since its only concern is communicating with the controller on the SSD and not the NAND packages themselves.
One risk though is if the OS tries to write anything to the drive or make any other change that will cause the console’s DRM to freak out. I am unsure of the PS5 has such an issue though.
I have Western Digital Black SN850 1TB (P/N WDS100T1X0E) variant without heatsink (WD no longer sells these?), I do have a big heatsink on (bigger than the original one actually) yet it is causing issues to my PS5. It started recently tho, looks like some data corruption or something. I purchased it when WD launched them, so I must have an early firmware, not sure how to find out firmware version tho, PS5 shows 00AFY0.
Can I update PCIe Gen4 SSD in a PC that is PCIe Gen3 tho? I do not have a PC with Gen4 unfortunately
