Hello
is it possible to install any CRM on WD?
If yes, how?
thanks
I believe there are many applications supported by Multibay My Cloud.
Please be specific which particular CRM you want to install on your WD device.
Hi, their
actually i want to install suiteCRM. But i even don’t know which system (PC/Appel/something else…) i have to use. SuiteCRM is writen in PHP so i guess it should run on any browers. Sorry i miss same IT basics
thanks for help
rainer
