How to get Gmail Backup
I want to know how to get the backup of my Gmail accounts. I want to deactivate my ex-employees Gmails accounts. But having a few important data at there,so also wants the backup of the Gmail Accounts. Suggest me any easy methods.
Thanks in advanced
Here is the solution to your problem of getting back up from your Gmail Accounts.  You can use the Gmail Backup Accounts
Gmail Backup Tool is an advanced tool that can filter all of your data and install at the desired location. Its easily support the windows 2003 to Latest versions of Outlook. The software can create backups of only those files selected by customers.
Visit here:-  https://www.datavare.com/software/gmail-backup-expert.html
Here is the solution to your problem. You can try the  Gmail Backup for getting your data into PST, EML, EMLX, MSG and MBOX formats. The software is easy to use and never miss your important data throughout the backup. You can try the software without any doubt.
Visit here:- https://www.completeconverter.com/gmail-backup/
You can simply go with the Gmail Backup tool for getting your database from the PST, EML, EMLX, MSG, and MBOX. This application is light in weight that can easy to install and never make your computer slow. Gmail Backup tool is designed to work on all Windows Operating systems and is suitable for all its versions. Both windows 32 and 64bit. Are completely supported by the application.
Visit here:- https://www.filefixutility.com/gmailbackup/
Gmail Backup tool can do anything for you.
You can simply go with the Gmail Backup tool for getting your database from the PST, EML, EMLX, MSG and MBOX. This application is light in weight that can easy to install and never make your computer slow.This is the most reliable solution of your problem. The Gmail Backup is the light in weight that can easy to install and never make your computer slow. The software can easily provide a database of unlimited and big size files at the same time, without any data loss and without making duplicate files.
Visit here:-https://www.toolsbaer.com/gmail-backup/
You can choose to create a separate Gmail account for backup. Then you can go to the Accounts tab of your Gmail account.
Then choose the import option to import all the mails and calender to your backup account.
So that you can have the backup of all the ex-employees data.
I hope this helps!
Regards
Apps4Rent | o365cloudexperts
Simple and efficient solutions are available for taking Gmail Backup Software. You can download this Gmail Backup Software and convert or export all mailbox items from Gmail to EML, MSG, PST, EMLX, and MBOX file format. You can suggest this utility to others.
Visit at more info: http://www.download.adwages.com/gmail-backup-software/
Hey
To backup Gmail try ShDataRescue Gmail Backup Tool. The utility is one of the most reliable and trustable solution. Backup Gmail emails on Windows in the form of PDF, PST, MBOX, and EML Files.  Free demo version of the utility is also available for users. You can easily take Google Drive Backup into external Hard Drive, Flash Drive, and Local machine.
Are there any recommendations on soft from google?
Easily backup all your Gmail email items with the help of the Gmail backup tool. With this tool, you can take the backup of your Gmail email without any issue. With this tool, you can take the backup of Gmail email and can convert Gmail email to PDF, MBOX, PST, MSG, etc.
You can use the Gmail Backup Accounts.
I would also recommend using the Gmail backup tool. You can find this function under ´Download data´ and then ´select data to download´. After you click on the the button ´create backup´, you can choose which data you would like to download.
Not only the Gmail Backup tool allows you to make Backups of e-mails, but also several other tools such as Gmvault Gmail Backup. This tool is completely free.
Try Cloud Backup Tool it easily backup all Gmail email items into PST, MBOX, EML, EMLX formats. Now users can straightforwardly backup Gmail emails without any loss. This app quickly shift emails, inbox, outbox, sent drafts files, and other data from Office 365 files. The free trial version allows exporting 10 emails for free. The tool 100% safe and secure.
To get Gmail backup, use CubexSoft Email Backup Software. A direct and error-free utility to backup emails from 30+ web sources to PST, PDF, MSG, EML, MBOX, MHT, HTML, IMAP Server, Exchange Server, Outlook.com, Yahoo Mail and more. With the help of the app, a user is free to backup emails not only from Gmail account but also from G Suite, Yahoo Mail, Office 365, Exchange Server, IMAP Server, Roundcube and more. Try free Email Backup Software version now to know its entire options and features.
