So, my trusty My Book drive suddenly wouldn’t turn on. I tried different wall sockets and even a different adapter so see if it was that. Long story but nothing worked. So I thought well no problem, I know it’s just a standard 3.5 inch Sata drive in there, so I thought “I’ll put it in one of my old HDD enclosures!” I did and now I keep getting a “This computer cannot read this drive” when I plug it into my Mac and when I try it on my windows PC it just shows up as unallocated space.
I called WD and they told me that their drives have a hardware encryption etc
I also called a HDD recovery service that said they can get the info off for me and decrypt the drive but its obviously incredibly expensive so I’m leaving that as a last resort.
Does anyone know how I can personally go about decrypting my HDD?
I’m having the same issue. Keep getting error message “The disk you inserted was not readable by this computer.” even after trying with another controller board with the same encryption numbers. The USB port broke off the original board which is why I’m having this issue. Drive is good… just can’t get to the data. Please let me know if there are any known solutions. I’m willing to pay a significant amount of money to retrieve my data.
It can be done. The encryption key is stored in a block near the end of the raw disk (raw = not in the enclosure). That key is encrypted, based on your password, or if none is used, on a factory-set key. Here is a paper that describes the setup:
I myself have successfully removed the 4TB drive from a MyBook Essential and installed it into my desktop. I did not reformat. Instead, I set up an encryption layer to simulate the JS528S chip that is on the MyBook’s USB-to-SATA PCB.
I can do this in linux only, so don’t ask how to do it in Windows, please. If I can recover your data for you, it has to be by using one of my computers.
I just want to say that Thomas saved my precious data. He helped me to decrypt my WD My book via email. He spent hours helping a noob like me doing all of this in Ubuntu. I have never used any version of Linux before, so I must say it was very interesting. My drive had a Symwave chip and it worked. The first sector was also corrupt so he helped me with that aswell. I sent my first e/mail at 1 PM and it was solved at 1 AM. So I must say he was fast and very professional. He did it completely free of charge to. Amazing! Thanks Thomas!
I want to say to everyone that Thomas Kaeding helped me save all the data from a friends hard drive. It was a MyBook Essential 2TB USB3.0, model number wdbacw0020hbk-00. The USB-to-SATA board fried and did not start the disc, nor it got recognized by the computer. I testes with different power supply and USB cable and nothing worked. This board has a Symwave SW6316 chipset which applies hardware encryption of AES-256 to all data. After a few minutes of sending the disc blocks containing the key to Thomas, he was able to point me with the unscrambled key and how to use it in Linux (I used Ubuntu Mate).
This guy deserves to be contracted by WD and receive big money from them. WD should provide a tool, made by this guy, to help all the people solve this problem in the event of a failed external case. This is a well known problem and many people loose invaluable data because of this problem. If this only works in Linux, at least WD should provide a virtual machine made from this guy, so that people can retrieve their data. After that, the drive can be formatted and used without encryption, in a typical USB-to-SATA external case.
Thank you very much Thomas! I hope someone from WD sees this and takes the action of contacting you so that you receive the credit you deserve, and also the monetary compensation.
Guess what? I’ve just got help from Thomas decrypting and recovering files from an old MyBook drive with a faulty USB interface. His procedure worked also in my case with the INIC-1607E chip flawlessly.
I agree with the ones saying that Thomas should be paid by WD for the service he’s providing to their customers!
Thomas helped me decrypt my hard-drove as well; the controller board on my essential died and he had it fixed within a few e-mails. Thank you very much! 10/10
I’m currently using ddrescue to try and clone my failed drive to a spare so I can try to repair it and retrieve some very important pictures, and I wouldn’t be able to do that if it wasn’t for Thomas’ amazing help with the encryption and the very detailed use of commands. In my experience it’s rare that someone is so helpful to someone they don’t even know. Thank you very much, Thomas!
I also am having the same issue, if anyone could give me some pointers as well, I’ll love you forever! I’ve tried everything I know to get this to work, but am at wits end!
In a nutshell, if you have a hardware encrypted My Book Model XYZ, and the enclosure fails, all you need to do is obtain the exact same enclosure from XYZ and insert the drive.
How can I determine the enclosure model if it has since been lost and I only have the drive?
This is a 500 GB WD Caviar GP WD5000AAVS - Can you tell me which model I will need to get?
The link does not provide this information.
@SBrown: What would be the process for obtaining a new controller? Since opening the drive enclosure to determine whether it’s the SATA-USB bridge or the drive voids the warranty, how does one go about getting a new enclosure out of warranty?
