Thank you.
I just bought a “My Book Studio LX External Hard Drive (3TB)” and have used the WD Smartware Software to put a password on the drive. I am using the Firewire 800 cable/connection on my Macbook Pro running Leopard.
What is the proper way to shut down/disconnect the drive after use? Do I drag the drive to the garbage and then drag the WD Smartware Icon to the trash, or do I just disconnect the firewire cable after draging the drive to the trash, or am I suppsed to turn off the power in the back of the drive? What is the exact, correct process?
I am very concerend about this because my older My Book drive no longer mounts on my computer (different post and issue) and I want to make sure I never have this problem again.
I greatly appreciate any response.
