How do I prep my MyBook to use to backup my 2 MacBooks using TimeMachine?
I bought a MyBook about a year ago that was on a good sale and haven’t used it yet. I want to back up to MacBooks. It’s not a MyBook for Mac, so I presume I need to reformat it. Is that sufficient prep or is there another step I need to take?
Thanks for any/all help :slight_smile:
Hello Houseofjanzen,
You just need to reformat the drive to make it fully compatible with your Mac.
How to partition and format a WD drive on Windows (8, 7, Vista, XP) and Mac OSX
