How do I delete / remove the WD “Smartware” bloat-ware partition from my external hard drive ?
Hi.
Question is in the title. :wink:
Thanks in advance for any help !
Further info.
I’ve had this drive for a couple years now, and always wanted this stupid bloat-ware removed from it, and have tried many things to get rid of this dumb-ware occasionally, but have only had the opportunity to completely reformat it recently, and still cannot get rid of the “bloat-ware”. :angry:
I find this so annoying. I have bought about 3 other WD drives since then, and have been happy to see this **bleep** is no longer built into those drives [I would never buy one again if this had continued]
I tried reformatting the drive to fat32 in Mac using disk utility, which didn’t work, AND in windows, using the traditional reformat tool, and also with a program called HP USB disk storage format tool ;
NONE of which has worked.
I really liked the ability to password protect the drive, but could this sort of thing not be available as a download, smaller than 615mb!?
Hammey :
Does this process actually remove the vcd? As far as I can tell from that article, it looks like it only HIDES the VCD, without actually removing it?
Cheers Joe !
That’s the impression I got, and the same impression I receive from all the posts I can find in this forum and in articles and posts elsewhere.
to WD.
I’m really disgusted WD hasn’t posted a simple and easily accessible fix for this, especially with all the other posts in these forums with users showing their hatred of this rubbish.
I shouldn’t have to waste so much of my time to get what is essentially pre-installed malware off my drive.
