How different between WD My Passport and WD Elements? Which should I buy
Can anybody show me how different between WDBBEP0010BBL-NESN (WD 1TB My Passport USB 3.0 Portable Hard Drive) and WDBUZG0010BBK-NESN (WD 1TB Elements Portable Hard Drive)?
I usually backup files and work on several operating systems such as Mac, PC and some Linux distros. I’d like to have fast reading / writing speed because I often move huge files/folders which are more than 2GB+ up.
Which one should I buy?
Thank you!
Either one will be fine for you since both of then are USB 3.0.
On the links below, you will see the drives information page.
WD Passport
http://support.wdc.com/product/install.asp?groupid=218&lang=en
WD Elements
http://support.wdc.com/product/install.asp?groupid=306&lang=en
Thank for your response!
But I still wonder how do they get different price?
is there special features that I don’t know yet?
