I need an urgent help on these drives, I used sg3 utility format this drive from 520B to 512B per block, but windows disk manager still can’t create partition on it. Did I miss something here?
Thank you in advance!
I have a similar issue with these disks in a Dell Perc 6i . i cannot make a raid of any type , the dell diagnostics test the disks fine…did you find a solution to your issue?
