I have ripped CDs to WMP10 in mp3 format, then sync’d them to my clip before. I haven’t used it in about a month to do so (was just listening to FM).
Today I went to do it, and have ALL kinds of issues:
1. WMP10 changed my rip format off of mp3. Had to change it back.
2. When it went to sync, it would convert it back OUT of mp3 and onto a wmv (or wma?) Had to make mp3 a file that WMP10 was default for.
3. FINALLY got it to rip in mp3, then sync mp3. HOWEVER… my clip isn’t showing the music in the music folder. I can *see* it using WMP10, I just can’t see it using my clip.
So, I went to FAQ and it says I can rip CD contents directly… HOWEVER in Step 3 it says when you insert your CD, it will ask you what you want to do. Well, my problem is that I have long since checked the box to tell it to “Take No Action”… HOW do I reset this so that it will prompt me?
Or, can you tell me what to do to get it to rip/sync with WMP10?
Thanks.
