I have a 4TB Mybook that I had never used before I plugged it in the other day. It doesn’t show up in File Explorer, so I can’t access it or format it. I opened disk management and this is what I get:
“Disk 2” is the Book. When I try to initialize the disk with either GPT or MBR it says “The request has failed due to a fatal device hardware error.”
In Control Panel it looks like this:
Attempting to update the drivers through there or disk management tells me that there are no available drivers or that the right drivers are installed, which clearly isn’t the case. I can’t find drivers for it on the internet though.
I have tried other USB ports, and other computers, neither of which have worked.
I have WD Drive Utilities and it looks like this:
Erasing the drive in there doesn’t work either: ![4|386x500]4 hosted at ImgBB — ImgBB
The Quick and Complete drive test buttons don’t do anything at all.
Any help would be greatly appreciated.
As per the shared image, your drive is unknown and not initialized; whenever there is “disk unknown not initialized” issue occurs, your hard drive may show unallocated space in Disk Management, and the data on drive will be inaccessible or else there is another situation: there is no disk space shown in Disk Management (same as in your case).
However, you can try the below methods to resolve the issue:
Method 1. Use Disk Management to fix not initialized error on an external hard drive
Connect the uninitialized external hard drive to your PC.
Press Win + R keys, type: diskmgmt.msc and hit Enter.
Find the uninitialized, unknown external hard drive with I/O device error > Right-click on it and select Initialize Disk.
Then set the disk to initialize and set the disk as MBR or GPT.
After this, you may reboot your PC and keep all changes. Now, your external hard drive will be recognized and read by Windows again.
Method 2. Run CMD to repair I/O device error on not initialized external hard drive
This CMD command would erase all data on the uninitialized hard drive, which you can later restore after repairing the external hard drive not initialized, with the help of any data recovery or partition recovery software:
Press Win+R > Type: diskpart and hit Enter.
Type: list disk and hit Enter.
Type: select disk F and hit Enter; (replace F with the drive letter of an uninitialized external hard drive) .
Thank for your reply, Jose.
The first solution did not help because now when I open disk management and right click the external hard drive, “Initialize Disk” is grayed out. The second solution didn’t help either since there is no letter for the drive.
As your WD is not showing up and you are unable to format it in disk management then I would suggest you to choose the diskpart command to clean your disk and assign a drive letter to it.
Follow the below steps in order to clean the disk using diskpart command:
Open Start.
Search for Command Prompt, right-click the top result, and select the Run as administrator option.
Type the following command to run DiskPart and press Enter:
diskpart
Type the following command to list all the active drives and press Enter:
list disk
Type the following command to select the drive that you want to clean and press Enter:
select disk DISK-NUMBER
In the command, replace DISK-NUMBER with the drive number you want to repair as it appears in the “Disk” column. If you do not perform this step correctly, you could erase the wrong drive. Proceed with caution.
Type the following command to wipe out the drive and press Enter:
clean
Type the following command to confirm the drive still selected and press Enter:
lisk disk
Quick note: The output should include an asterisk (*) next to the selected drive.
Type the following command to create a new partition and press Enter:
create partition primary
Type the following command to select the new primary partition and press Enter:
select partition 1
Type the following command to make the partition active and press Enter:
active
Type the following command to format the partition using the NTFS file system, set a drive label, and press Enter:
format fs=FILE-SYSTEM label=DRIVE-LABEL quick
This example formats the drive using the NTFS file system and names the partition “Data”:
format fs=ntfs label=Data quick
Type the following command to assign a letter and make the drive available in File Explorer and press Enter:
assign letter=DRIVE-LETTER
In the command, change DRIVE-LETTER for the letter you want the drive to use, which is not assigned to another device.
This example assigns the “G” letter:
assign letter=g
Type the following command to terminate DiskPart and press Enter:
exit
Type the following command to close Command Prompt and press Enter:
I don’t know if this will help anybody but on mt new WD drive it won’t show up in Explorer if you have used WD’s security app to set a password.You have to run the app, enter the password you set, thern it works.
Is everything working now? When I had a similar issue with my external hard drive not showing up, I was really frustrated. However, I found this article: https://www.cleverfiles.cоm/howto/external-drive-not-recognized-windows.html, and it was a game-changer for me. The guide walks you through several troubleshooting steps to get your external drive recognized again, from checking the connection to adjusting device settings. It’s a very comprehensive and easy-to-follow guide, so if you’re still having issues, I highly recommend giving it a try. Hopefully, it works for you too! Let me know how it goes or if you discover any other helpful solutions.
When you encounter the ‘The request failed due to a fatal device hardware’ error, it typically indicates a severe hardware problem. Your drive may have bad sectors, which are parts of the disk that can no longer reliably store data. On the other hand, the hard drive may have suffered physical damage, such as from a fall, electrical surge, or exposure to extreme temperatures. This guide provides some basic troubleshooting steps, but if all else fails, it’s best to seek help for professionals.
