HELP replacing my External Hardrive
warrenty is good. Problem is i’m going through this distributor part. What do I do from there? Do I have to contact one of these guys to replace it?
this place has terrible customer service. fail
Hello mate,
This is a user to user forum.
Maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email.
To Contact WD for Technical Support:
http://support.wdc.com/contact/index.asp?lang=en
