Hi , I was wondering if there are any good quality headphones from 5-15 dollars max. I really dont like the stock and am hoping to get betters soon. Thanks!
Message Edited by sansaer on 01-02-2008 04:05 PM
$10 isn’t going to get you much, but go between $15 and $30 and there are some really good options. KSC-75 clip-ons and Sony Fontopia and Panasonic Marshmallow earbuds are ones I’ve seen recommended frequently (I use the Fontopias myself and I like them quite a bit.) If in doubt, go to an electronics store that sells headphones and ask if you can try them out with your Express.
I use Sonys with the roll-up case at Wal-Mart. Cost 9.95 and sound great! They are also comfortable and don’t fall out of my ears.
what is the model?
Sony’s model number is MDR-E828LP.
thats the same thing as the fonatopia:smiley:
thanks any ways
Another vote for the Koss KSC75!
They’ll beat any earbud at any price range except maybe the Yuin pk1
The are very known for their sound quality and you can’t go wrong with them for that price. You’ll probably have to shell more then 60$ to get anything better sounding. And when I say 60$ I mean 60$ for brands like Sennheiser, AKG, Grado etc… Not some overpriced ■■■■ like Sony or Boss.
Message Edited by SanToast on 01-06-2008 10:54 AM
