Hello
We have a GSPEED Q and I need to change hard drive to expand capacity but I don’t have the CD with the raid configuration software.
Unluckily my product is to old for WD and they stop support and the software is not available to download
Can I have a solution ?
Thanks a lot
Hi @WillPi,
Please contact the WD Technical Support team for best assistance and troubleshooting:
https://support-en.wd.com/app/ask
OK
thanks for the answer.
Were you able to get a copy of the configurator tool? I am in the same situation. Thanks
I found the soft for windows thanks to a request with Qwant but I was not able to find a solution for Mac
Can anyone provide me with a copy of the RAID configuration app for Windows and/or Mac? All I got from WD support was that the product is no longer supported.
