I replaced a failed drive in my G-SPEED eS unit, but the rebuild does not automatically start. The array shows a status of Disabled, and the Maintenance link shows the replaced drive as Offline Disk. I have powered the unit off and back on, rebooted my workstation, but nothing seems to trigger the rebuild process. I have irreplaceable files on the array and desperately need to get the array back online so that I can copy them to another location. Can anyone please help me?
Hello KFrohne,
Maybe you should try contacting G-tech Technical Support about this.
To Contact G-tech for Technical Support
http://support.wdc.com/support/case.aspx?lang=en
