formatted drive reports it "needs to be formatted"
I have an Extreme 240 SATA drive that I am using as an external drive using a USB 3.0 connection. The drive connects and works fine when connected to a Win 7, Win 8, and Mac system. But when I connect it to my WinXP system it gets recognized and assigned a drive letter but reports it “needs to be formatted” and is unreadable.
Any ideas and solutions to this problem?
what file system is the drive formatted in? it sounds like you are using exFAT. there is a patch that would need to be installed on the XP machine for exFAT support.
Thanks drlucky I think you may be right. The drive was formatted by an Atomos Ninja2 HD recorder and the manual said it formats in exFAT and FAT32. I’ll do a search but do you know where I can get the WinXP exFAT patch?
From the MicroSoft support page here:
http://support.microsoft.com/kb/955704
The reason your drive works perfectly on Windows 7, 8, and Mac but says it “needs to be formatted” on Windows XP comes down to two likely compatibility issues:
1. The Partition Style is GPT
Modern systems (Windows 7/8 and Mac) format drives using GPT (GUID Partition Table) by default. The standard 32-bit version of Windows XP does not support GPT at all. It only recognizes the older MBR (Master Boot Record) style. To Windows XP, a GPT drive looks completely blank or “RAW,” which is why it prompts you to format it.
If you need the drive to work on Windows XP, you must backup / copy your data on a newer computer, change the partition style from GPT to MBR (using Disk Management on Windows 7/8), and then re-format it. [ Related guide: Should I Use MBR or GPT for SSD on Windows 11/10/8/7? ]
2. The File System is exFAT
You mentioned that the hard drive can seamlessly read and write on both Mac and Windows; I think it is formatted as exFAT.
Windows XP does not support the exFAT file system out of the box. You don’t need to format the drive on the Windows XP machine if this is the issue. Now you only need to download and install the official Microsoft exFAT update for Windows XP (KB955704) on your XP machine. Once installed, XP will read the exFAT drive without asking for a format.
