Format or not on 6 TB MyBook
My computer is a laptop, Windows 7, fully updated with all MS updates issued. I purchased a 6 TB MyBook over the holidays for it. The MyBook is formatted as exFAT. While WD utilities work fine with this, I purchased this MyBook to use as a system backup with WD-True Image or stand alone Acronis True Image 2017. I have downloaded both the WDTI2016 (Acronis WD Edition). Each time I attempt to use this WD provided program, it fails to complete due to an error, usually a Connect Error. Acronis TI 2017 also fails. My wife’s computer (Windows 10) has a WD MyPassport backup drive and WDTI2016, and it works fine for both backup and for a system image. The MyPassport is formated NFTS. Based upon that, should I reformat my MyBook from exFAT to NFTS so that I can try the true image, and will it then do regular file archive and routine file backups under the new formatting?
Yes.
The unit comes exFAT for cross-platform compatibility, but NTFS is the better file system for Windows.
You should format your new WD My Passport to NTFS. Since you only use Windows and prioritize backup reliability, NTFS is the best choice for your needs.
While exFAT is not inherently unsafe, it lacks a critical safety feature called journaling. A journaling file system like NTFS keeps a continuous log of file changes. If your drive is suddenly unplugged or loses power during a heavy backup, NTFS uses this log to prevent data corruption. Because exFAT lacks this safety net, it carries a higher risk of data loss during accidental disconnections.
exFAT is designed for universal compatibility across Windows and Mac, but it offers fewer data protections. NTFS is Windows’ native file system, meaning it is highly optimized for your OS, handles large backup data sets more efficiently, and includes advanced security and error-recovery features. Both file systems easily support your 5TB drive capacity and large movie files, but exFAT provides no benefit since you do not use macOS. [ Read also - exFAT vs. NTFS: Which is Better for Your Drive ]
Since your drive is brand new, formatting it now is ideal before you fill it with data. To switch to NTFS, simply plug the drive into your PC, open File Explorer, right-click the drive, and select Format. Change the file system dropdown to NTFS, keep “Quick Format” checked, and click Start.
