Format my WD My Passport drive
I have been using my WD Passport drive on my Windows PC. I am changing to a new computer. How do I format my drive so I can now use it to back up from my Mac:
Hi @EllenCleary,
Pleas refer to article: Steps to Format a Drive for Use with Windows or macOS
Also, Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting:
To use your WD My Passport drive for Mac backups, you need to format it using Mac’s built-in Disk Utility tool. Because formatting completely erases all data, you must choose your file format depending on whether you want a standard storage drive or a Time Machine backup drive.
Make sure all files currently on your WD Passport are copied onto your new Mac’s internal storage (or another temporary drive) before you format the hard drive. macOS can natively read Windows-formatted (NTFS) files, so you can plug the drive into your Mac, drag your files over to save them, and then proceed with formatting.
1. Connect the drive to your Mac, then open Disk Utility: Press Command + Spacebar, type Disk Utility, and hit Enter.
2. Click the View icon in the top-left corner and select Show All Devices, then choose the top-level name of your WD My Passport in the left sidebar.
3. Click the Erase button in the top menu bar.
4. Choose your settings:
• Name: Type a name (e.g., “Mac Backup”).
• Scheme: Select GUID Partition Map.
• Format: Choose APFS if you want to use Apple’s automatic Time Machine backup. Choose exFAT if you want the drive to work on both Mac and Windows PCs.
5. Click Erase.
If you don’t want to format your Passport drive and prefer to copy files manually via drag-and-drop, you can use a third-party NTFS for Mac driver to do this. [ Read also: How to write to an NTFS external drive from Mac ]
