I forgot the password related to http://192.168.60.1/UI/
How can i reset it?
Thank you
Check the full user manual for how to reset/restore the MPW to factory defaults. You need to do this back to System Only (your data will be fine). Once correctly completed you will need to set up device as new again., and adding a password is one of the steps
