I just bought the WD 2TB EasyStore external drive. When I transfer files from my Mac or another drive they download and then vanish. This is ridiculous, waiting hours for files to download and then they disappear.
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting: https://support-en.wd.com/app/ask
There could be several reasons why your transferred files are disappearing. Here are some troubleshooting steps to identify and resolve the issue:
Check the file transfer process: Make sure you’re copying or moving the files correctly. Double-check the destination folder on your WD EasyStore drive to ensure the files are actually being transferred there.
Verify the available storage space: Confirm that your WD EasyStore drive has enough free space to accommodate the transferred files. If the drive is nearly full, you may need to delete unnecessary files or consider using a larger external drive.
Check for hidden files: Sometimes, files may appear to be missing because they are hidden. On your Mac, open Finder, go to the external drive, and press Command + Shift + Period (.) to reveal any hidden files.
Confirm file system compatibility: Ensure that your WD EasyStore drive is formatted in a file system that is compatible with both your Mac and the other drive you’re transferring files from. Ideally, it should be formatted in a file system like exFAT, which works well with both macOS and Windows.
Check for errors on the drive: Run a disk check or scan on your WD EasyStore drive to identify any potential errors. On macOS, you can use the built-in Disk Utility application to perform a First Aid check on the drive.
Test the drive on a different computer: Connect the WD EasyStore drive to another computer, preferably one running a different operating system, and see if you encounter the same issue. This will help determine if the problem is specific to your Mac or if it’s related to the drive itself.
Update drive firmware and software: Visit the official Western Digital website and download any available firmware updates or software specifically designed for your WD EasyStore drive.
Contact WD Support: If the issue persists, it’s advisable to reach out to Western Digital’s customer support.
Remember to back up any important files before attempting any troubleshooting steps that involve modifying or formatting the drive. Further, in case of any data loss situation, you can try using data recovery software such as Stellar Data Recovery, to recover any lost or deleted data from any storage device.
To fix the issue with your WD 2TB EasyStore external drive, start by checking the file system format using Disk Utility on your Mac. Ensure the drive is formatted as ExFAT if you use it with both macOS and Windows or Mac OS Extended (Journaled) if it’s only for macOS. If necessary, back up any data and reformat the drive using Disk Utility. Additionally, check the drive’s permissions by right-clicking it, selecting Get Info, and ensuring you have read and write access. Lastly, run First Aid in Disk Utility to detect and repair any drive errors. After these steps, try transferring your files again.
Were you able to fix it eventually? If you’re still facing the issue, I came across this helpful source that offers methods how to fix raw usb drive without format. The guide at https://www.cleverfiles.cоm/howto/recover-data-raw-usb-drive.html provides step-by-step instructions on how to recover data and repair the drive, which could be really useful if you want to avoid losing your files. It covers a few different approaches and tools you can use to get your USB drive back to working order without the need for a full format.
There are various reasons that possibly can lead files to not show up in the external hard drive.
Some files are mistakenly deleted.
The external hard drive or USB flash drive gets accidentally formatted.
The files are hidden.
The file system of this external drive is corrupted.
Accordingly, you may follow these steps to fix the issue:
Run file recovery software to get back the files that disappeared from your WD external HD on Mac.
Make the hidden files/folders visible in Finder.
Run First Aid in Disk Utility to fix the disk error
Reformat the WD external drive on a Windows PC.
One more thing, macOS might have issues with case-sensitive file names if there are folders with names that differ only by case (e.g., homework and Homework). If you find such conflicting items, you can rename homework to homework02. Also read: How to Fix Files Disappeared from External Hard Drives/USB Drives on Mac
